[WANTED] 4 spd input shaft
You are gonna have to be more specific.
Are you just looking for a stump, like a line-up tool? Or do you need a working one. If yes on the latter, then you will need either a tooth count or an application, such as, for the; 2.66low box, or the 2.47low box. or the .73O/D box, etc. There are at least 5 different ratios that I have found, and I think none of them share input shafts. Low gears is another story
And, of course why? Are your splines twisted up? Or?
If you can twist that 1 x 23 Shaft, Ima thinking it's time to move up to the Hemi box. But Ima thinking you already knew that, and just want to get this box back into sale-able condition.
got a good one, but I think it is from an overdrive, is 22 teeth, 3.09 ratio? $60.
Had one but cant find it. -_-
quick question for your thread here.
which A833 is a direct swap to the 727 trans. with the drive shaft length in mind.
23 spline or 28 spline. <- i might have the splines wrong. brain fart.
"B" or "E" body A833. Splines could be 23 or 18.
One of those has the shift pad in a bad spot for A-bodies. I believe it's the B.
And the shift pad on the E,while usable is some 9 or 10 or 8 inches further to the rear,making fabrication necessary.
