4-speed hump sealing
Hyper Henry
Ontario, Canada
Hey Guys
What are you using to seal the cut outs/welds around the 4-speed hump after you install in the floor??? I was going to just use some caulking or body shop seam sealer but would like to find something that I could brush on so I could put a good amount around the seams.
Thanks
Derrick
Body seam sealer, and you can get it in a can so you can brush it on.
Brushable body seam sealer, top and bottom.
