If you want to make it easy use Schumacher big block motor mounts for your appication. You can use a standard Big block 1970 on up 10" Bell housing and flywheel. Use a standard A body 23 spline 4 speed and shifter linkage. Pretty simple swap as long as you have a stick already pedal assy. If not you will need all the pedals and S bar etc. I have what you need. I am in Michigan.
