[WANTED] 4 Speed Parts Wanted..
44067gtdart
Nevada
I need parts for a 70 Duster 4 Speed conversion.. I have the pedals, trans, bell housing, shifter and handle.. I need EVERYTHING else.. If anyone can tell me exactly it is I need, That would be helpful also.. I am in Henderson, Nv.. 89014.. Thanks..
You will need; a clutch kit,the release and pilot bearings, the release fork and pivot, all the linkage to the pedals,the little rubber firewall boot, the shift rods and bushings, the tunnel hump and new carpet,the shifter boot and trim-ring,the shifter mounting plate and special mtg screws,the reverse switch wiring harness, possibly the dash-mounted reverse-lite,and possibly a driveshaft with the correct yokes.
