4 speed rebuild
What is the the trick to hold the countershaft end bushings in place?
I put mine all together and the front bushing slipped and I had to dissemble the whole trans. @#$%^&.
I put some grease on them, and put a piece of 3/4 inch conduit the exact with of the counter shaft inside of it. Once you start to put the shaft back in you may need to use a long screw driver to move the washers around to line them up.
