nico06
Member
i have a barracuda 68 with original front disc kelsey 4" bolt pattern i want to change to 4.5" bolt pattern does somebody did it ? could you help me ?
THANK YOU
THANK YOU
THANK YOU
SSBC has a drum to disc kit, which has both SBP and LBP holes.
The rotors look very similar to the Mustang ones.
http://www.ssbrakes.com/commerce/detail/index.cfm?nPID=8789
Hotrodsusa once carried a Wilwood kit for discs to discs. They may still have them. (?) Remember though, any of the new kits are going to be probably 3-4 times the expense of the alternatives described here.
Oh, okay I didn`t know you were in France. That makes a big difference. Good luck with your search.
because i am in france you can't help me !!
Cheapest and easiest way is to have them redrilled to 4.5". Sent mine to Moser.
Mark, how long ago was that done? 2006? I contacted Moser about doing a set for me about 3 years ago. They said that they no longer do that modification due to the fact that the machine they used to do it, had been replaced by another (more money making) machine.
Nico06, list your location with your avatar and that will help people direct you when advising.
i knew this one but it still 4"" i am looking fo a kit where the bolt pattern change to 4.5"
I believe there is a typo in the ad, see the "Bolt Pattern5x4 in.& "
I think they left off the "5x4.5 in. "
A few members bought this set and the rotors have both patterns.
See here:
http://www.ssbrakes.com/commerce/detail/index.cfm?nPID=8556
it looks ok but does is go on the original spinkle xithout any more change ?
