Gen 2, would that be be 67-72 A-body?Not really related , but TTI recommends 1 3/8'' for clearance in a gen 2 , with their 2'' headers , worked for me .
Yes, I expect exhaust clearance to be an issue so I will definitely take that into consideration.
The incline is taken with the car on stands, level as far as I can determine. It’s not easy to find a level surface I’m the car. I’ve used the top of the door side, the bottom of the window opening.
I did think of something, I will try to determine the side to side offset of the trans cross member bolt hole for the trans mount tomorrow.
Yes but , 67-76 those engine compartments are the same, but obvious body changes over the years which you already knewGen 2, would that be be 67-72 A-body?
Wise words. I’ll get the oil pan and pump on and go from there.One other issue with putting it that far to the pass side is centerlink/idler arm clearance to the oil pan. Mine comes VERY close at full lock. You may want to bolt up the steering linkage to make sure it clears
Honestly, I would just bolt the trans up, whatever manifolds/headers you intend to run, and steering linkage, and lock the engine in wherever it clears everything. Height-wise, put it as low as you can without having clearance issues with the centerlink/idler arm. Done and done
***EDIT*** - Also, make sure you bolt up an oil pump. Mine comes pretty close the DS K-member.
Great input! I’ll see what the angle on my Team G intake is. Thanks!make sure you allow for any intended body rake when at ride height on it's wheels. not many cars sit perfectly level front to back and if you plan the car to be slightly nose down that'll reduce the 3 degrees you have set up. set the body at the rake it'll ride at and most intakes set the carb mounting pad level while setting the motor at a 3-5 degree angle.
neil.
