[FOR SALE] 425cid SB 360 rotating assembly
hemijoejr
NJ
Rating - 0%
0   0   0
No pictures as of yet. I will post them as soon as I can. Absolutely KILLER rotating assembly for an LA 360 for sale. 425cid!! NEW Never used only mocked up. Mopar performance 4340 forged 360 crank offset ground to a 2" rod journal. 4.100" stroke nitrated and radiused oil journals, and internally balanced. Custom billet steel Crower rods 6.350" long for 2.00" journal and .927 pins. Custom ROSS dished pistons for 4.060 bore .927" wrist pins. 1.5mm 1.5mm 3mm oil ring, Set up for 11-1 with Eddy 65cc heads. This has been stored for about 10 years. Crank should be polished before use and rods have very slight amount of surface rust that does not cover the whole rod. just speckled and pistons are currently mounted on rods. $2500.00 FIRM + Shipping PayPal accepted as long as the fees are paid. located in Central NJ This cost me A LOT more Crank and machine work was $1200+, Rods were $1300+, pistons were $800+ NO RINGS and NO BEARINGS Please PM me for further details. Joe
