[SOLD] 426(360) stroker engine for sale
demonduster
is everything
Rating - 0%
0   0   0
NOW WITH DYNO RESULTS ! 468.2 Hp@ 5200prm. 510.4 torque@4400rpm .Pump Premium. It idles with 14-15"of vacuum and sounds really tame. Timing set at 34 degrees. Plug gap .40
Set up as street torque engine on pump premium. Add some more cam and Head porting for 500+ Hp. Heads are ootb, Rockers Hughes 1.5 . Dyno by Dunnuck Racing, An msd blaster coil, REV-N-NATOR prototype ignition box, Fire core ignition wires, Hooker Super Comp 1 3/4 X 3" and an HP 950 that is set up just rich enough to be safe for testing was used courtesy of Dunnuck Racing for dyno pulls
Sorry to go off topic may I ask what size your rim and tire combo is front and back. I really like the look
Front are Bridgestone Potenza s03 pole position 225/50/15 (NLA) and the rear are Bridgestone re050 235/45/17 . The wheels are American Racing Ansen Sprint. The 17" are NLA. 15x7 and 15x8 are still available new.
Is the engine still available? Why are you selling it and was the thousand miles a 1/4 at a time? I'm interested if you still have it, let me know.
Still for sale
Short block built by Hughes engines low miles, maybe 1000 street miles/no strip. was in my Duster. Last run was on dyno,see sheet above
Hughes cam : HEH3237AL
Edelbrock Heads OTB
Hughes Rocker arms and shafts, pushrods
Edelbrock Victor 340 intake manifold.
Milodon oil pan. Road race style low profile
Edelbrock Elite Valve covers.
Hughes girdle
Used TTI Headers
$5000.00 must pick up/arrange freight PM if interested. Located in LaPorte IN 46350
510 LB FT of torque. Hay that's the same as a stone stock 455 Buick!
Seriously, nice engine.
