1. 408 swinger
    408 swinger FABO Gold Member FABO Gold Member
    2,397
    2229
    Nov 12, 2010
    Iowa
    Local Time:
    8:58 AM
    Working on an 02 Jeep GC. 4.0 with 42RE. Complete rebuild, valve body updates, and new convertor. Air checked both servos and clutch packs before installing valve body. All is fine. Shift kit is the Trans-Go Jr. Has manual low, but, no reverse. Has second gear. Third and o.d.Put gauge on that servo and the pressure is waay low. Like 50 in low, 75 to 100 in reverse. I've checked the case for cracks. Had valve body back out to double check my work. Air checked again with trans in vehicle. Everything hits/moves. Did all the other pressure checks as well. All were at low end of spec. Oil pump gear clearances all checked good. Had the o.d. unit back off to check all clearance there too. All good, nothing fried. I'm frickin stumped. What say the trans experts in FABO-land?
  2. greg ducato
    greg ducato FABO Gold Member FABO Gold Member
    34
    39
    Sep 17, 2015
    Weatherford
    Local Time:
    8:58 AM
    Check the reverse boost valve to be sure it is free, check that there isn't a checkball restricting the separator plate feed hole for reverse. You can actually leave the check ball out of that part of the casting for more reverse apply oil.
    • Thanks! Thanks! x 1
    • MOPARMAGA
      MOPARMAGA FABO Gold Member FABO Gold Member
      1,459
      945
      Aug 20, 2019
      Yakima Wa
      Local Time:
      6:58 AM
      Have you tried adjusting the linkage ?
    • 408 swinger
      2,397
      2229
      Nov 12, 2010
      Iowa
      Local Time:
      8:58 AM
      Yes. Spot on.
