dadodgekid
When in doubt... floor it
Well I am selling this setup again...
K1 4.250 stroke crank - 340 mains snd honda rod journal 1.889
K1 lightweight rods 6.250 length 3/8 arp2000 bolts
Custom je piston, domed. If you leave the dome and zero deck with .039 compressed gasket... 14.2 to 1 comp. Too high for me (spec sheet for pistons are for a different build but works perfect for this combo)
Ive got the crank and one rod and piston mocked up in a 340 block I have, lots of room everywhere! Small notch at the bottom of the bores and you are all set!
* No rings or bearings
$1550 for everything ( cheaper than a 408 street assembly )
Ill post more pictures later today.
