robcuda
Hey guys,
Anyone use a pulse from one of the speed sensors ('97 46re, 518) to operate a Intellitronix type speedo? I have no schematic and hoping someone may know what wire! Below are the instructions provided with digital dash.
Thanks a bunch if you have info!
Rob
"For vehicles which have a vehicle speed signal from a transmission sender or ECM, tap the VSS wire (consult a vehicle service manual or wiring diagram to determine correct wire color) and connect it to the white speedo sending wire from the digital dash. Note: If your vehicle is equipped with an electronic transmission there will be an electronic vehicle sender with either two or three wires coming off of it."
Rob
