Are the ears on a 5.2 magnum block the same pattern as a 5.9? Or did they carry on with the 273/318 LA design, with the aft driver's side ear being 1/2" farther back than the 340/360?
Are you looking for motor mounts?Are the ears on a 5.2 magnum block the same pattern as a 5.9? Or did they carry on with the 273/318 LA design, with the aft driver's side ear being 1/2" farther back than the 340/360?
Well, I might be. I've got 2 of Schumacher's kits to put a 340 or 360 in a 63-66 A body, and if they don't fit a 5.2 I'll either have to get some that do, or adapt one of these to fit.Are you looking for motor mounts?
Jake
Since I already have the 340/360 brackets, that's what I'm hoping for.Although I don't know from experience, I understand the 5.2 brackets would be the same as 340/360 brackets for a A body.
What year car?Well, I might be. I've got 2 of Schumacher's kits to put a 340 or 360 in a 63-66 A body, and if they don't fit a 5.2 I'll either have to get some that do, or adapt one of these to fit.
I think he means a magnum 318/5.2 not an LA.Just did that on my 63 (B Body)with the 340/360 Schumacher brackets on a 1970 318.Just had to make a spacer for the driver side to bolt the bracket to the block.
For the mount insulators they may be different.
'64 Barracuda.What year car?
Exactly. The 5.2 I'm planning on putting in now (I originally thought it'd get a 360) isn't here yet, I was just thinking about whether the mounts I have will work or not.I think he means a magnum 318/5.2 not an LA.
Magnums are all the same.Exactly. The 5.2 I'm planning on putting in now (I originally thought it'd get a 360) isn't here yet, I was just thinking about whether the mounts I have will work or not.
Cool, that's what I was hoping. Thanks.Magnums are all the same.
That makes sense, with it being an early (first year? second?) block. The one I'm getting is an '01, so hopefully it'll have the same spacing as the 5.9. I saw a 318 in a wrecking yard that was a hybrid, '91 or so, basically an LA motor with a magnum front end. I guess it had a 1 year only water pump on it? Strange.
