[FOR SALE] 5.7 Hemi Engine
krw340
This is a 2014 engine with 75 miles. Removed from a 2014 Ram 1500 4X4. It's advertised as 395 hp/ VVT/aluminum heads, distributorless/two spark plugs per cylinder. Comes with intake manifold, exhaust manifolds, computer, and engine wiring harness as pictured. Changed plans and now using a LA small block stroker motor. Asking $4750 plus shipping
prefer local pick up
May consider trades. I need a complete large bolt pattern rear end for an a-body. 8 3/4 or Dana, could be narrowed. 3500-4000 stall torque converter for a sb 727, and a complete front disc brake assembly. I don't want your Harley, quad, snowmobile, or an other non mopar related item ! Thank you. Located in Michigan 48661
Truck motors dont have VVT they do have MDS thou -steve
GTCarLot.com > Engines > Ram > 1500 > 2014 > 5.7 Liter HEMI OHV 16-Valve VVT MDS V8 > Engine #84776204
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for the 2014 Ram 1500 #84776204
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Big Horn Crew Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Big Horn Crew Cab #87290508
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Big Horn Crew Cab #86287863
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Big Horn Crew Cab #85707394
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Big Horn Crew Cab #85707694
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Big Horn Crew Cab #85489207
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Big Horn Crew Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Big Horn Crew Cab 4x4 #84776204
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Big Horn Quad Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Big Horn Quad Cab #86073364
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Big Horn Quad Cab #85031329
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Big Horn Quad Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Big Horn Quad Cab 4x4 #85508006
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Express Crew Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Crew Cab #85812168
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Crew Cab #85705649
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Crew Cab #85706248
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Crew Cab #85708549
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Crew Cab #85314629
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Crew Cab #85206086
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Crew Cab #85206347
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Crew Cab #85128911
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Express Crew Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Crew Cab 4x4 #85128368
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Crew Cab 4x4 #84889382
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Express Quad Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Quad Cab #85811899
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Quad Cab #85707982
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Quad Cab #85395247
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Express Quad Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Quad Cab 4x4 #85863958
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Quad Cab 4x4 #85864948
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Quad Cab 4x4 #85255998
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Express Regular Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Regular Cab #94294448
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Regular Cab #90504348
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Regular Cab #85922413
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Regular Cab #85925274
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Regular Cab #85808062
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Regular Cab #85396204
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Regular Cab #85312625
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Express Regular Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Regular Cab 4x4 #86923111
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Express Regular Cab 4x4 #85973595
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Laramie Crew Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Laramie Crew Cab #89900179
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Laramie Crew Cab #87972867
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Laramie Crew Cab #86916391
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Laramie Crew Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Laramie Crew Cab 4x4 #86922222
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Laramie Crew Cab 4x4 #85132458
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Laramie Limited Crew Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Laramie Limited Crew Cab #87126420
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Laramie Longhorn Crew Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Laramie Longhorn Crew Cab #93340275
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Laramie Longhorn Crew Cab #89729305
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Laramie Longhorn Crew Cab #87126987
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Laramie Longhorn Crew Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Laramie Longhorn Crew Cab 4x4 #87693120
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Mossy Oak Edition Crew Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Mossy Oak Edition Crew Cab 4x4 #90308721
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 SLT Crew Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 SLT Crew Cab 4x4 #84889190
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 SLT Quad Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 SLT Quad Cab #86073643
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 SLT Quad Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 SLT Quad Cab 4x4 #97950551
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Sport Crew Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Sport Crew Cab #89899942
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Sport Crew Cab #89902267
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Sport Quad Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Sport Quad Cab #94304632
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Sport Quad Cab 4x4
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Sport Quad Cab 4x4 #87099966
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Sport Regular Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Sport Regular Cab #93645946
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Sport Regular Cab #85312916
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine on the 2014 Ram 1500 Tradesman Regular Cab
5.7 Liter HEMI OHV 16-Valve VVT MDS V8 Engine for 2014 Ram 1500 Tradesman Regular Cab #85313495
Our goal is to provide the highest quality automotive photo archives available online.
GTcarlot.com Home - Privacy Policy - Terms of Use - Search - Car Shows, News and Events
© 2013 World Motor Media World Motor Media
All data is provided for entertainment purposes only, is subject to change without notice and is provided without warranty of any kind.
Thank you for visiting GTCarlot.com
I am being told that truck engine's didn't come with VVT (2014). Here is a window sticker with that option. If anyone else has a window sticker of their 2014 5.7 1500 truck with VVT and want to share it please post it. Or if you have information that shows the 2014 Ram 1500 5.7 trucks came with the VVT please post. If it didn't come with it I will edit my ad. The last thing I want to do is be dishonest here !
Thank you
WINDOW STICKER
2014 MODEL YEAR
RAM 1500 EXPRESS QUAD CAB4X2
PRICE INFORMATION
MANUFACTURER'S SUGGESTED RETAIL PRICE OF THIS MODEL INCLUDING DEALER PREPARATION
Base Price: $ 29,080
RAM 1500 ST QUAD CAB 4X2
Exterior Color:Flame Red Clear Coat Exterior Paint Interior Color:Black / Diesel Gray Interior
Colors Interior:Cloth 40 / 20 / 40 Bench Seat
Engine:5.7-Liter V8 HEMI(R) MDS VVT Engine Transmission:6-Speed Automatic Transmission STANDARD
EQUIPMENT (UNLESS REPLACED BY
OPTIONAL EQUIPMENT)
FUNCTIONAL/SAFETY FEATURES
Trailer Tow with 4-Pin Connector Wiring 7 Pin Wiring Harness
26-Gallon Fuel Tank
Advanced Multistage Front Airbags
Supplemental Side-Curtain Front and Rear Airbags Electronic Stability Control
Anti-Lock 4-Wheel Disc Brakes Speed Control
Sentry Key(R) Theft Deterrent System Power Accessory Delay
Automatic Headlamps Locking Tailgate Spray-In Bedliner
Class IV Receiver Hitch
INTERIOR FEATURES
Front Armrest with Three Cup Holders Air Conditioning
Uconnect(R) 3.0 AM/FM
6 Speakers
Media Hub (USB, Audio Jack) Rear Folding Seat
Power Front Windows w/ 1-Touch Up and Down Feature Power Door Locks
Rear Under Seat Storage Compartment Tilt Steering Column
Electronic Vehicle Information Center 12-Volt Auxiliary Power Outlet
Black Vinyl Floor Covering
EXTERIOR FEATURES
Halogen Quad Headlamps
17-Inch x 7.0-Inch Steel Wheels P265/70R17 BSW All Season Tires Full Size Spare Tire
Power Heated Mirrors with Manual Fold-Away Black Door Handles
Black Front Bumper Black Rear Bumper Black Grille
PRICE INFORMATION (contd.)
OPTIONAL EQUIPMENT
Customer Preferred Package 25C $ 1,810 20-Inch x 8.0-Inch Aluminum Wheels
P275/60R20 BSW All Season Tires Body-Color Front Fascia
Body-Color Rear Bumper with Step Pads Fog Lamps
Carpet Floor Covering Front and Rear Floor Mats Delete Spray-In Bedliner
Delete Class IV Receiver Hitch
Popular Equipment Group $ 535 Cloth 40 / 20 / 40 Bench Seat
Remote Keyless Entry with All-Secure 6-Speed Automatic Transmission
3.55 Rear Axle Ratio
5.7-Liter V8 HEMI(R) MDS VVT Engine Dual Rear Exhaust with Bright Tips
Uconnect(R) 5.0 AM/FM/BT $ 465 Integrated Voice Command with
Bluetooth(R)
5.0-Inch Touch Screen Display SiriusXM Satellite Radio w/ 1-Yr Radio Subscription
For More Information, Call 800-643-2112 Overhead Console
Rearview Mirror with Microphone
Single Disc Remote CD Player $ 195
DESTINATION CHARGE $ 1,195
TOTAL PRICE:* $ 33,280
