boosted
Life Needs Air
Can the exhaust be swapped sides so that they are forward facing? Trying to get an Idea on my twin turbo setup.
I have made the necessary provisions for when I turbo mine. Only did the pass side and will make a log and tie the drivers side in. It’s easy to do.
That’s gonna be a ride for sure!Ahh that gives me a good understanding. I will have twin 76mm to start with then work my way up. The bottom end on my motor is all forged with a 6.1 crank, h beam rods and forged 9.6 to 1 pistons. Should be around 20lbs of boost to start off with and work my way up from there.
NoI remember with the 5.7 that you could accidentally bolt the heads on the wrong side, and not notice untill the exhaust manifolds wouldn't bolt on. Could you swap the heads on purpose so the exhaust was flipped around?
