5.9 Magnum bottom end swap
82CRUISER
NC
Anyone taken a Magnum bottom end and put a edelbrock intake and carb on or used J heads with same setup? Any help pls
LA style heads, aren't a bolt on for Magnums. You can buy a Magnum dedicated manifold, or swap to EQ CH318B Magnum heads.(Drilled for LA bolt intakes) Another option is using a dedicated jig to drill the heads to LA style. A few members here, have such a tool.
Abodybomber, have you ever heard of someone doing this to Edelbrock Magnum heads? Redrilling them for "LA" use?
