5.9 Magnum Cam bearing orientation
thomasfouraker
Jacksonville
Any source that indicates the correct indexing of cam bearings for the magnum motors? The 5.9 I am in right now has had the bearings replaced, and from the looks of the other assembly I want to confirm they were placed correctly before using their correct positions for reference.
Thanks!
Thomas
Orientation? Pull the old bearings out and look at where the oil passage bores are.
