5.9 Main Cap Torque Specs FSM vs Larry Shepard?
macdrew77
Camino, CA
So the 1998 FSM says 85 ft lbs for main caps, but Larry Shepards magnum engines book says 100 ft lbs. Which is correct?
I go to 85 if using factory bolts. But I use a good thread lube on them. Like ARP. Any time I use an upgraded fastener (like an ARP main stud or bolt) I use that manufacturer’s listed torque spec. I said all of that to say this, the “correct” torque is whatever was used when the line bore/hone was done.
This.
I'd run ARP and whatever they suggested, if I had the money at the time.
Anyone do 100 foot pounds on factory bolts? I followed the Larry Sheppard book, and now kinda worried.
