For those of you running 5.9 swaps, at what temp does your motor settle at when fully warmed up?
is that a swap? or is it a stock truck?190-195 is the normal thermostat for the 5.9.
Normal actual running temps on mine is 190-210 and 210 is where the fan comes on, but it only comes on if doing under 30 or sitting in stopped traffic.
Thermostat only controls when the flow starts, has no effect on high end of operating temperature.
IE the LOWEST temp the engine should run at is the thermostat spec.
Common mistake.
