[SOLD] 500 cu in Big block, Brand new engine
Mopar Mechanical Parts For Sale
Thread Status:
  1. jrlegacy23
    jrlegacy23 68 Barracuda
    2,610
    282
    Jun 27, 2006
    Laurens, NY
    Local Time:
    3:07 PM
    Contact Seller
    500 Cu in Big Block (400 block), Freshly machined, internally balanced, and painted Hemi Orange, never assembled. Engine is ready to be assembled. Bored .033" over.
    4.15" 440Source stroker crank
    KB forged pistons with full floating pins
    Eagle H-Beam RB rods, with ARP Bolts
    440source Aluminum heads
    ARP Head Bolts
    Complete Felpro gasket set
    Hughes Performance Roller cam
    Coated cam bearings, installed
    Brass distributor drive gear
    Mallory Unilite distributor (used)
    Milidon 7+1 Oil pan
    Milidon 1/2" pick up tube
    Torker 383 Intake (used)
    Crower roller lifters (used)
    Melling High Volume oil pump
    Polished Stainless steel shorty headers
    ProForm 1.5:1 roller rockers with chrome moly shafts (used)
    Billet rocker shaft hold down kit
    3/8" Chrome moly ball/cup pushrods
    440Source neutral balanced chrome harmonic balancer fluid damper
    Total seal, file fitted chrome moly piston rings
    Tri-Metal rod and main bearings
    Billet aluminum valley hold down bars
    Neutral balanced 440source flexplate
    Cloyes Hex-a-just True Double roller timing chain
    Billet fuel pump block-off plate
    I believe I have just about everything needed for completion except the Carb, valve covers, and some smaller nickle/dime stuff.
    PM me here for more info or email me at jrlegacy23 @ yahoo. com without the spaces. I am located near Cooperstown, NY 13326
    I am asking $6,000 or best reasonable offer. Pick up only, but will meet you somewhere for a non refundable deposit based on the distance that I have to drive. Will consider partial to whole trades for small block depending on setup.
    Here is a pic of the head set on the painted block and one of the headers:
    [​IMG]
    [​IMG]
  2. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    19,762
    6780
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    2:07 PM
    ..........I got some sb parts if ur interested in some kind of a trade.......i dont need the heads and some other stuff................kim.............
  3. jrlegacy23
    2,610
    282
    Jun 27, 2006
    Laurens, NY
    Local Time:
    3:07 PM
    I am looking to sell the complete package. I am putting it together little by little each day. If I complete it prior to selling it, I am going to put it in my Dart.
Thread Status:
