Sedanman
67-9 Valiant specialist
I bought this axle for the center section and have no need for the rest. It was in a Chevy Vega so it has all of the vega/monza suspension bracketry and 4 lug bolt pattern. It has been narrowed to 54 1/4 outer axle to outer axle,has 10x2.5 brakes, vega E brake cables (may be adaptable),the axles are resplines with factory bearings. The one axle (non adjuster side) had the spline twist and had to beat it out so it does need a new bearing or respline another axle with bearing $450
