What was the part number?
Well I'll be doing the fabled super six swap. (intake,carb,linkage, etc)...but then again what wont I be doing to the RUSTER...
After I made the first post I went looking and it seems like I can get a full gasket set from summit -->
FEL-KS2103 Fel-Pro Gasket Kit Sets
Gaskets, Full Set, Chrysler/ Dodge/ Plymouth, Mopar 6-Cylinder, Set
Today $56.39
Brand: Fel-Pro
Product Line: Fel-Pro Gasket Kit Sets
Part Type: Engine Gasket Sets
Gasket Set Type: Full gasket set
Head Gaskets Included: Yes
Intake Gaskets Included: No
Valley Pan Included: No
Oil Pan Gasket Included: Yes
Rear Main Seal Included: Yes
Exhaust Manifold Gaskets Included: Yes
Exhaust Pipe Gasket Included: No
Valve Cover Gaskets Included: Yes
Valve Stem Seals Included: Yes
Water Pump Gaskets Included: Yes
Timing Cover Gaskets Included: Yes
Timing Cover Seal: Yes
Water Neck Gasket Included: Yes
Fuel Pump Gasket Included: Yes
Distributor Gasket Included: Yes
Fuel Injector O Rings Included: No
Upper Intake Manifold Plenum Gasket Included: No
Head Fasteners Included: No
Quantity: Sold as a set.
Gaskets, Full Set, Chrysler/Dodge/Plymouth, Mopar 6-Cylinder, Set
Now you would think that if it comes with an exhaust manifold gasket that is also includes the intake
and for $56 I'll pick up 2!! for what Advance wanted.--I'm soooo confused
