Ya i know i could make better power with a single four.....but.....which 6-pack intake would be the best all around set up on a stroked small block.....edelbrock with the holleys or mod man with the demons.....thanks webby.
I've run neither, so take this with a grain of salt . A side by side visual comparison looks to me like the Mod Man may be better for you. It looks to have a larger plenum area and shorter runners so the upper rpm power would be better imo. The Eddy would probably make more low end torque, but that's not a problem on stroker's, they already have plenty.
I guess it depends on what you want to do. I have been 11.57 @ 118mph with a 402 stroker, factory sixpack setup, heads,exhaust manifolds, full exhaust, on g60-15 polys in a 3700lb car.
