/6 to v8 swap
1fastvaliant
New Member
Good evening all,
I will be swapping a 318 from a 4 door 1972 Valiant into a 67 Barracuda. I am using the k-frame from the Valiant. Are there any unique issues I need to be aware of? Will the 67 only idler arm on the Barracuda work with the 72 k-frame? I am using the 904 tranny from the valiant as well. Will the driveshaft length be ok? Both cars have the 7.25 rear.
Thanks
Glen
You're gonna need the idler from the '72, but everything else should bolt up. If the '72 driveshaft is too long use the one out of the '67.
