bootsnbolts
1962 dodge lancer GT: 'lola'
my completed work list:
1) carb rebuild
2) timing chain and TC set, ALL of it
3) remanned radiator, all clamps and hoses
4) water pump
5) brakes
6) brake lines
7) master cylinder
8) shocks, front and rear
9) oil sending unit
10) fuel filter (metal)
11) ignition coil
12) alternator
13) starter relay
14) accelerator pedal bolt
15) engine loom
16) dash loom
17) motor mounts
18) valve lash
19) valve cover gasket
20) headlight switch
21) rotor
22) dist. cap
23) spark plugs
24) door pin
25) steel wheel replacement
26) front passenger wheel bearings
27) greased/adjusted steering box
28) bulbs
29) vacuum tree cap
30) wiper blades
i THINK that's it...
some of those things seem minor, trust me, they were NOT...the smallest things caused us the worst problems. next on the project list is:
steering box
front right wheel drum
front end alignment
leaf springs (6'ers)
disc brake conversion
floor pan
exhaust manifold gasket
compression test
rebuild fuel line (to stock placement)
gas sending unit
ammeter
body work/paint
...and as soon as i don't hear any more funky noises....stereo!
we'll be doing a pull and rebuild eventually, but she runs fantastic as she is, and that's something that has to be scheduled in for a school break, since this is my daily runner. a few pics, starting with the engine as she was when i bought her:
and current (yes i know, still a dirty mess but, SO much better!):
from lola, our three cars:
from emma, our three cars:
rear ends:
marylin:
1) carb rebuild
4) water pump
5) brakes
6) brake lines
7) master cylinder
9) oil sending unit
11) ignition coil
12) alternator
13) starter relay
15) engine loom
16) dash loom
17) motor mounts
18) valve lash
21) rotor
22) dist. cap
23) spark plugs
24) door pin
28) bulbs
29) vacuum tree cap
30) wiper blades
steering box
front end alignment
floor pan
compression test
gas sending unit
ammeter
body work/paint
rear ends:
marylin:
