62 Valiant temperature control cable
62 Val
Active Member
Federal Way,WA
My heater temp control cable snapped right at the control lever. Does anyone have one? What is involved in replacing it? Is this a simple fix? How does it attach at either end? Is the cable the same part used in the 1960-1962 Valiants and Lancers? Any help appreciated...-Dan
Simple is a relative term. In you Valiant it may not be that bad to replace. It's always easy the 2nd time you do it but the first time can be challenging.
I've used cable from a lawnmower and it worked just fine but it's not exactly the correct size so the clamps on the ends may not hold properly. You're best off with the correct cable if you can find one.
