.620 mechanical Purple Shaft?
Mopar Performance Issues
  1. 67charger383
    67charger383 Well-Known Member
    60
    16
    Feb 26, 2020
    Maryland
    Local Time:
    6:44 PM
    Will this cam work with my 383?
    12-1 compression, 915 heads, Weiand Tunnel Ram, 4.11 gears, E85 conversion
  2. MOPAROFFICIAL
    MOPAROFFICIAL FABO Gold Member FABO Gold Member
    6,458
    5404
    Jun 1, 2016
    Beach
    Local Time:
    3:44 PM
    Sure. I'd install it 6* advance.
    Pay attention to the lash setting, cold .
    • Agree Agree x 2
    • Thanks! Thanks! x 1
    • Garrett Ellison
      Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
      2,918
      2298
      Jan 1, 2018
      Southwest VA
      Local Time:
      6:44 PM
      Is it the '67 Charger in your avatar and what's the tire size? Hot strip/street car or drag only?
    • 67charger383
      60
      16
      Feb 26, 2020
      Maryland
      Local Time:
      6:44 PM
      Hot street and strip car, 295/50/r15s on 15x12 wheels with 3800lb SS springs and Gabriel HiJackers
      Nobody builds quick '67 chargers and they are one of my favorite mopars.
      • Like Like x 2
      • 67charger383
        60
        16
        Feb 26, 2020
        Maryland
        Local Time:
        6:44 PM
        Which would be a better cam, the .620 purple shaft or this GK mushroom cam im thinking about too? Screenshot_20200809-095117.png
        • Like Like x 1
        • Garrett Ellison
          2,918
          2298
          Jan 1, 2018
          Southwest VA
          Local Time:
          6:44 PM
          I've seen some magazine "street" cars from way back when run the mushroom cams. I like the numbers on the GK cam, very much like a slower lobe rate roller cam. But I'm going to sit back and see what the others say, but I think it would work pretty well advanced 6 degrees too.
          • Agree Agree x 1
          • K.O. SWINGER
            K.O. SWINGER Well-Known Member
            1,261
            529
            Nov 18, 2010
            oregon
            Local Time:
            5:44 PM
            seems like a whole lot of stick for the street, I assume it's a manual transmission. I don't claim to be an expert on camshaft mating but that's more duration than I would be comfortable in anything but a full race application
            • Agree Agree x 1
            • RustyRatRod
              RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
              64,404
              37357
              Jun 7, 2010
              Georgia
              Local Time:
              6:44 PM
              I like the shroomer.
              • Agree Agree x 1
              • 67charger383
                60
                16
                Feb 26, 2020
                Maryland
                Local Time:
                6:44 PM
                Agree
                • Like Like x 1
                • yellow rose
                  yellow rose Master Of Insanity
                  24,451
                  20454
                  Jun 19, 2015
                  Walking a crooked mile
                  Local Time:
                  3:44 PM
                  If you don’t run the mushroom cam I’d love to buy your lifters.
                  PM me if you are interested in selling them.
                  • Like Like x 1
                  • 67charger383
                    60
                    16
                    Feb 26, 2020
                    Maryland
                    Local Time:
                    6:44 PM
                    Not mine yet. Ive been talking to the owner.
                    • Like Like x 1
                    • rumblefish360
                      rumblefish360 So close, yet so far away FABO Gold Member
                      39,012
                      10587
                      Jun 21, 2005
                      New York, on a Island
                      Local Time:
                      6:44 PM
                      The difference in cams as to which one is better is based on head flow for starters. Whats the ratio?
                      • Agree Agree x 2
                      • K.O. SWINGER
                        1,261
                        529
                        Nov 18, 2010
                        oregon
                        Local Time:
                        5:44 PM
                        Daddy likes a big old butt like 456 to go with a big lumpy stick! :rolleyes:
                        • Like Like x 2
                        • Agree Agree x 1
                        • DrCharles
                          DrCharles Well-Known Member
                          937
                          682
                          Jun 7, 2012
                          West Plains, Mo.
                          Local Time:
                          5:44 PM
                          I have a lightly reground Mini-Express mushroom setup in my 451 and have fun with it on the street (4-speed and 3.91 gears)
                          (Original cam specs: .654 gross lift, .024/.028 lash, 278@.050). After restoring the lobe taper: .652 gross lift, .018 lash, 272@.050. Idles at 1100 rpm or so, 8" vac. It really starts to come on above 3000 rpm and so far I haven't had the nerve to find the high end of the power band :D
                          But that GK mushroom (or even the .620 FT) is an awful lot of cam for a 383. You'll have to wind the piss out of it to take full advantage, and hopefully your 915 heads are ported some too.
                          • Agree Agree x 2
                          • DrCharles
                            937
                            682
                            Jun 7, 2012
                            West Plains, Mo.
                            Local Time:
                            5:44 PM
                            Daddy probably doesn't do much highway driving either! :poke:
                            • Like Like x 1
                            • K.O. SWINGER
                              1,261
                              529
                              Nov 18, 2010
                              oregon
                              Local Time:
                              5:44 PM
                              That was my point.
                            • oldkimmer
                              oldkimmer FABO Gold Member FABO Gold Member
                              16,457
                              4856
                              Nov 11, 2006
                              Kindersley, Saskatchewan,
                              Local Time:
                              5:44 PM
                              Mushroom cams bridge the gap between a sft and a roller. Ur motor will need to be apart to install the lifters. It’s more a race only cam. Have the guides been shortened? Port work? Street or strip. How much lift can the pistons handle. Give us more info to go on. Is it stick or auto? U will need more gear and a stall approaching 4000. The .590 is a better cam. Kim
                              • Like Like x 1
                              • Agree Agree x 1
                              • '63GT
                                '63GT Well-Known Member
                                1,478
                                1518
                                Jun 9, 2018
                                Turlock, CA.
                                Local Time:
                                3:44 PM
                                I used to run an Ultradyne NF Solid that is very close to that stick in a 383 very much like yours. It liked 7500 rpm and a 5400 converter
                                • Like Like x 2
                                • oldkimmer
                                  16,457
                                  4856
                                  Nov 11, 2006
                                  Local Time:
                                  5:44 PM
                                  Exactually
                                  • Like Like x 1
                                  • '63GT
                                    1,478
                                    1518
                                    Jun 9, 2018
                                    Turlock, CA.
                                    Local Time:
                                    3:44 PM
                                    Sorry, Kim. was responding to the OP..
                                    I used to run that .590 too in my 383. good stick. (feels like a lifetime ago..)
                                    • Like Like x 1
                                    • 512Stroker
                                      512Stroker We are all here because we are not all there.
                                      1,782
                                      1249
                                      May 30, 2016
                                      Freedom, MO
                                      Local Time:
                                      5:44 PM
                                      That GK cam card is alot of cam.
                                      Hope you have a really good set of well ported heads with the proper springs and rocker arms.
                                      • Like Like x 1
                                      • oldkimmer
                                        16,457
                                        4856
                                        Nov 11, 2006
                                        Local Time:
                                        5:44 PM
                                        Me too. I was agreeing that u need big gears and a very high stall converter. Kim
                                        • Like Like x 1
                                        • '63GT
                                          1,478
                                          1518
                                          Jun 9, 2018
                                          Turlock, CA.
                                          Local Time:
                                          3:44 PM
                                          YES! I had 5.13s and a low gear trans.
                                          • Like Like x 2
                                          • 67charger383
                                            60
                                            16
                                            Feb 26, 2020
                                            Maryland
                                            Local Time:
                                            6:44 PM
                                            I think I'm going to get the solid .620 purple shaft. I have 4.11 gears. I don't know what converter to get because I want it streetable
                                            • Like Like x 1
                                            • fishmens67
                                              fishmens67 Well-Known Member
                                              8,382
                                              6052
                                              Nov 10, 2012
                                              idaho
                                              Local Time:
                                              5:44 PM
                                              4500- 4800 stall would be good in the b-body.
                                              I think the 590 would be a better choice for the combo, heads being the limiting factor.
                                              • Like Like x 1
                                              • Agree Agree x 1
