OLFOOL
OLFOOL
I have a set of J heads with 68cc chambers, I need 62cc to reach the 10.4:1 compression I need. I already have a set of Cometic head gaskets .060" which I will use. Has anyone milled them that far?
Talk to your machine shop. They will do the milling and know how far they need to go to get there. (with or without your head gasket you want to use)I have a set of J heads with 68cc chambers, I need 62cc to reach the 10.4:1 compression I need. I already have a set of Cometic head gaskets .060" which I will use. Has anyone milled them that far?
Mine are 60ccI have a set of J heads with 68cc chambers, I need 62cc to reach the 10.4:1 compression I need. I already have a set of Cometic head gaskets .060" which I will use. Has anyone milled them that far?
I have oneMine are 60cc
Why the .06 gasket?
Do you know how far in the hole your pistons are? Might be cheaper to get thinner gaskets to subtract volume in lieu of milling the headsI have one
That’s what I run with my J headsSlap a cheap set of Mr Gasket 1121Gs on there and friggin send it.
I paid $140 for an 0.005" cut on both heads a few months back. You will need a few passes to get them down to 62cc.I have a set of J heads with 68cc chambers, I need 62cc to reach the 10.4:1 compression I need. I already have a set of Cometic head gaskets .060" which I will use. Has anyone milled them that far?
A lot of shops here charge like that - up to 0.015" is X $$, between 0.015" - 0.030" X $$ and so forth.Shops that charge per pass suck balls.
Talk about nickle and diming someone...
The set up is once... all it is after that on a run of the mill 'pun intended ' machine...is turning the dial before the next pass...or even easier selecting the amount/program.A lot of shops here charge like that - up to 0.015" is X $$, between 0.015" - 0.030" X $$ and so forth.
One place quoted me $220, I figured they didn't need the work...
How much did you have to mill from your intake?Mine are 60cc
Why the .06 gasket?
