63 and 65 door difference
Valiant63
Early A-body Valiants
eastern, PA and central Florida
If I have a 65 Valiant front door to put on a 63 Valiant, I know that the door will physically fit, but there is something different about the striker plate on the post. Can I change out the striker plate from a 63 to a 65 Striker plate to make the 65 door operate properly? Who knows this for sure?
1965
1963
Your answer is nope.
Unless you graft in a 65 striker plate mount.
I have those as well as good door skins if you want to fix what you already have.
No, the latch incompatibility is total. The door metal's different and so's the door jamb area. '64-'66, no problem, but '63 is the odd duck out.
