63 Dart, brake line
JimD
Mickleton,NJ
I'm changing my MC to a dual. I bought a new line block from Year One, now I have it in hand I see it has 5 outlets. 2 run through the block, 2 are next to each other, and 1 is one the side by itself. There were no instructions, can some one draw a pic, or tell me what lines go where. I fell like a dummy , but I'm going to install my self, Thanks for the help, Jim.
On your block two lines go in and 3 go out. Use rubber tipped air hose to figure out which holes go together. The in lines should be in the same plane and may have a switch between them. This is the "best" answer that I can think of. Good Luck.
As amx said, 2 go in-3 go out. The larger thread size is for the MC lines and the 3 smaller are wheel cyl. lines. There should be 2 out for the front, 1 for each side, and 1 single for the back, which will be the isolated one.
Do as amx suggested and find the 2 out for the front using air, this will be your front MC in and your 2 front outs. Blow it through either larger hole and check for air coming out 2 ports!!
Easy peezy!!! Good luck with your project, Geof
