63 dart question
69DARTS
69 Darts Rule
indiana
Just did this today
63 dart with a push button auto
When i go to push the reverse button
It pops back out
It does not seem to want to push in all the way.
Helps and hints
Thank u
Remove the dashboard faceplate (you'll have to remove the headlamp and windshield wiper switches; see here). Then you'll have access to the pushbutton mechanism, which should be lubricated every 55 years or so, whether it needs it or not. Use a good brand of spray silicone lube—quality matters a lot here; if you get the cheap stuff it can attack the plastic your pushbuttons are made of, and that's a bad scene. I use this kind. Spray the metal slides (behind the buttons) where they go through the rear wall of the button box. Put the straw in the park lever slot and spray to reach the hinge and spring. Operate the lever and buttons (you'll find them much smoother and more "clicky") and there's pretty good odds you'll find your reverse button stays pushed since its detent is now free to move into position.
Replace the light bulb while you're in there. The trick is to get some clear soft vinyl hose at the hardware store, 1/2" inner diameter. You need about 6 inches of it. Boil some water and bring it out to the car with you. Dip 1 inch of one end of the hose in the boiling-hot water for 30 seconds, then pull it out and immediately push the hot end over the bulb hidden amidst the pushbuttons. Once the hose slides over the widest part of the bulb glass, don't keep pushing. Let the hose cool for two minutes, then push inward and twist counterclockwise. Bulb comes out. Spray some of your silicone in the bulb socket. Install a new bulb the same way.
If Dan's suggestion doesn't cure it, check the cable itself. They are not known for going out of adjustment, but something else may have happened or the cable may be
dragging for some reason. Reverse is pushing the the cable into the trans to it's limit of extension in operation, not likely but a small chance it's binding for some reason.
Is the trans engaging reverse at all? Good luck, hope it is just a "gummy" mechanism..
