63 Dart vert/top fluid
JimD
Mickleton,NJ
What fluid is used on my 63, also where is the best place to buy new hoses for the top, thanks in advance Jim.
You can get the new hoses here: http://www.hydroe.com/product_detail.html?id=4988&parts=Dodge Dart All - Convertible Hose Set The original fluid is the same thing as auto trans fluid without the red dye. You can refill with Dex/Merc trans fluid. Here are their instructions for bleeding the air out of the lines and pump: http://www.hydroe.com/Tips_-_Cylinders__amp__Pumps.html Although this article mentions brake fluid, I have read somewhere on this forum that brake fluid will dry out the lines and make them weak and brittle. I have a 1967 Fury III convertible with the original plastic hoses. I topped off my pump with Dex/Merc trans fluid. No problems.
