63 dart visors
Dartnewbie
Former Dart owner
I finally found some visors for the dart but the passenger side one is real stiff and creaks badly when you move it up and down. Is there a way to remove the metal rod from the visor and lubricate the rod and put it back in? Not sure how these go together and don't want to pull the rod out if I can't get it back in.
Update: Nevermind. Figured it out. The rod is tapered on the end to allow you to push it back in. Works fine now.
