63dartman
I finally did it!! I now have 2 1/2 inch off the headers almost straight back into magnaflow performance mufflers. Man what a nice little rumble. I still have to finish it up but it sure sounds better than the old econo turbo mufflers. I also learned that the cutout that calls for a 1.25 radius on the crossmember mod needs to be just that or it will bottom out on the crossmember frame area I made mine 1.5 just to make sure I had enough room to run the pipes. Needless to say I now have a crossmember that can only have metal running half way across the bottom on the passengers side. I don't think it will be an issue though. Live and learn. Time for a few :drinkers::drinkers::drinkers::drinkers:
