[Found!] 64-65 LA 904 Speedometer Cable
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
Looking for a speedometer cable for a 64-65 LA 904. Damaged cable is fine as all I really need is the plug part that goes into the transmission. Pictures would be helpful
Hopefully the cable is damaged as I’d rather not mess up a good cable. Let me know!
How about this one?
There is a place called Speedometer Cables USA in Colorado that can make anything you need. Phone 888-907-6506
Just the part that goes into the transmission. The cable broke where it meets this part so I cut it off with my Dremel.
If you just need a plug to be a plug, I can get you in touch with my friend that made mine!
