64-66 abody radiator brackets for shroud
Heating / Cooling / AC
  1. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    53,049
    38554
    Jan 18, 2006
    Iowa
    Local Time:
    4:25 PM
    #928 is a 19" slant 6 auto/heater. The #930 has been chatted about. 22" 273 manual with heat only but mine has "AC" stamped in the tank.
  2. Syleng1
    Syleng1 Karma is real and Life is short... FABO Gold Member
    1,874
    1451
    Jul 5, 2005
    North Franklin, CT
    Local Time:
    5:25 PM
    Thanks Mike,
    I just responded to my own post with an EDIT update. I wonder if the top tank was changed on my auto radiator at one time.
    It seemed to be repaired or a few times repaired so it would make sense. The top tank is diffrent width than the 19" top tank I also have from 1966. Crap! so much for numbers matching show car.... time to tub and dub on airbags, the car is now worthless.
  3. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    11,675
    3252
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    5:25 PM
    Here is the page with the radiator part numbers. Note that this page superseded the same page dated May 1965 - this page is dated Mar 66
  4. toolmanmike
    53,049
    38554
    Jan 18, 2006
    Iowa
    Local Time:
    4:25 PM
    FYI The #2582*** number sequence started in 1966.
    1965 was #2524*** sequence.
  5. 65 Dartman
    11,675
    3252
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    5:25 PM
    So these numbers are still for 65, which won’t help Syleng since he’s looking for 66 numbers.
    • Agree Agree x 1
    • cosgig
      cosgig MoBro Inc. FABO Gold Member
      11,291
      4313
      Jul 20, 2008
      Pinckney, Michigan
      Local Time:
      4:25 PM
      Here’s a few pics of the 63/64 slant radiator with the corresponding shroud. I sold this about a month ago.
      • Like Like x 3
      • toolmanmike
        53,049
        38554
        Jan 18, 2006
        Iowa
        Local Time:
        4:25 PM
        • Agree Agree x 1
        • Big_John
          Big_John In my defense, I was left unsupervised.
          370
          383
          Nov 16, 2014
          Syracuse, NY
          Local Time:
          5:25 PM
          FWIW, this is the radiator in my '65 Formula S. It is not the original piece, but it does have the correct part number.
          It is 22" wide and has "AB" above the part number. I don't think the "AC" means "Air Conditioner".
          It also has the provisions in the brackets for shroud mounting.
          • Like Like x 2
          • toolmanmike
            53,049
            38554
            Jan 18, 2006
            Iowa
            Local Time:
            4:25 PM
            I never thought of that.
          • toolmanmike
            53,049
            38554
            Jan 18, 2006
            Iowa
            Local Time:
            4:25 PM
          • 66340SEDAN
            66340SEDAN FABO Member #3649 FABO Gold Member
            26,726
            28409
            Nov 20, 2006
            Minnesota
            Local Time:
            4:25 PM
            Ok, here is what I have....the 4 matching brackets are for a original 1966 A-body 22” radiator with a shroud.
            The shiny black bracket is the same as the other 4 except I think I drilled the bolt hole larger for some reason but I didn’t need the shroud anymore on that car so I removed it and installed it on my dads 66.
            The other bracket I believe is for a B-body car and it’s quite different, look at the pictures. The most obvious is the long hole for adjustment, but the curve and tab at the front are also different. The holes also don’t line up the same. Not sure where I got this, probably ebay but didn’t realize it was different till it matched them up.
            The reproduction B-body ones look just like the above mentioned bracket with the slot, I’m not sure if they will work or not but I’m guessing they won’t just bolt right up without some mods being made to get them to fit properly. If they are able to be used most will never even notice the difference.
            The original brackets are harder to find than the rare shroud....they were small parts and easily got lost! Hope this helps.....BTW, sorry the brackets are not for sale since they belong to a shroud I have.
            • Like Like x 3
            • Agree Agree x 1
            • 66340SEDAN
              26,726
              28409
              Nov 20, 2006
              Minnesota
              Local Time:
              4:25 PM
              [QUOTE="Syleng1, post: 1973152429, member: I’m curious if the repop brackets are correct.[/QUOTE]
              They are different
            • Syleng1
              1,874
              1451
              Jul 5, 2005
              North Franklin, CT
              Local Time:
              5:25 PM
              66340SEDAN- thank you for the pictures! I greatly appreciate those. It looks like I can bring those to my welding shop and work them in to submission for them to do as I need. They look longer and offset is further but i bet I can tweek them.
              Toolmanmike - Thank you for the pictures. I called my local Chrysler dealer to ask what the "AB" and "AC" ment and the guy a 40 year veteran Mopar parts dealer said even today the Chrysler number system is the part number then the revision.
              XXXXXXXX-AA, or XXXXXXXX-AB Etc. It is the way to show what updates are done so if a warranty part roles in and Chrysler wants to see it, they know what version they are dealing with.
              Learn something new everyday LOL!
              • Like Like x 2
              • Syleng1
                1,874
                1451
                Jul 5, 2005
                North Franklin, CT
                Local Time:
                5:25 PM
                They are different[/QUOTE]
                That is a real bummer as those re pops are like $65.00 on ebay. That's a lot to be wrong.
                You pictures show they are off quite a bit. Nothing my 100ton press can's straighten out. :)
              • cudamark
                cudamark FABO Gold Member FABO Gold Member
                7,239
                479
                Mar 14, 2009
                San Diego
                Local Time:
                2:25 PM
                Here's what I have for radiators in a couple of my original '66 Barracudas. My 273 4bbl 4 speed Hamtramck 49 state car has the 2582930, which has a 2 row core. My 32,000 mile survivor is a Formula S auto. LA plant Ca car. with heavy duty cooling uses a 2582975 which is a 3 row with a shroud. Neither car has A/C.
              • 65 Dartman
                11,675
                3252
                Sep 24, 2006
                Strasburg, VA
                Local Time:
                5:25 PM
              • toolmanmike
                53,049
                38554
                Jan 18, 2006
                Iowa
                Local Time:
                4:25 PM
