64-66 Barracuda side glass
midlifecuda
Can someone please tell me if there’s a difference between the driver side and passenger side door glass? When I put a straight edge on the glass there seems to be an ever so slight crown but it’s hard to tell for sure. The window edge chrome seems to have a curvature as well but almost more pronounced than the glass. These doors have been apart for years and I am in the process of re-installing the doors. Out of the four doors (2 left 2 right)side glass that I have, none seem to “curve” the right way for the pass side. The one that I thought may have the right ever so slight curvature for the driver side is it in and it meets the rubber weatherstrip well All be it it is adjusted as far as it would go so that it would meet the weatherstripping. When I had that piece of glass on the passenger side it didn’t quite meet the rubber weatherstripping even adjusted all the way so that it would. That’s when I realize there may be a slight curvature to the glass.
Glass may be the same but on a 64-66 there is a stainless steel trim on the back part of the glass that only goes one way.
See the stainless strip. The side glasses for the rear roll downs work either drs or pass.
That stainless molding is only on the door glass, not the quarter glass. It pops off fairly easily and can be transferred to the another door glass.
You'd have to flip the lower lift bracket too, if you want to swap sides with the door glass.
View attachment 1715584238 See the stainless strip. The side glasses for the rear roll downs work either drs or pass.
What color is that , OEM Barracuda Silver Poly? Same as mine but mines a 1-Day repaint 'sunburst silver'. It's pretty dang close! Trying to figure who's paint 1-Day auto body and paint used in 1996? 1 Step up from the Earls!
Thanks everyone. I thought they were flat but maybe some slight distortion that my straight edge is picking up. Yes I checked my straight edge!
Silver poly.
cudamark- I learn something new everyday. All theses years I’ve been keeping lefts and rights and I could had separated parts, had less inventory and a small box of steel. Thank you for this info!
