[SOLD] 64-72 Lower control arms W/ sway bar tabs. in Wisconsin
barracudadave67
Burlington, Wi.
I have a pair of 64-72 A-body lower control arms. They have been blasted, epoxy primed, and painted black. I have installed a set of new moog rubber lower control arm bushings. I also welded on a set of re-inforcing plates on the underside, of each. The T-Bar mounts swivel nice and easy. They have the swaybar tabs on them. You will need to add your own bump stops. These arms came off a 66 B-Cuda, with 10in drums. These arms will work with Kelsey-Hayes brakes also. $200.00 plus shipping from S.E. Wisconsin.
barracudadave67 PMs Welcome
