64 Dart 273 with 4-Speed Speedo Cable Leak
Vcode
New York
The speedo cable is leaking alot out of the housing where the metal cable goes inside. I got new seal and o ring. I know its the seal is leaking inside so that's why it is coming out of cable. I think someone put the seal in wrong. Which way is correct and how far down does it go into the plastic speedo gear.
I don't remember there being a seal in there. Just and "O" ring around the metal housing end where it goes into the tailshaft. If oil is leaking out of the speedo cable housing, you may need a new cable housing. I've seen some that were resealed with some good results. It's a matter of getting the housing totally clean. Once clean, use some of the liquid tool handle dip to reseal the housing. Just make sure to let it dry and cure completely before it gets subjected to oil again. If the housing is severely damaged, you'll probably need to get a replacement.
