64 dart post
Okie Dart
Member
Fairland OK
I am doing a resto on a 64 dart that has been in the family for ever.I am looking for reproduction window seals and am not having much luck. I have a new windsheild seal but am stumped on the plastc insert that goes in the groove on the exterior. My latest search which I have come up dry on is the rear glass ANY HELP WOULD BE MOST APPRECIATED thanks Don
:banghead:
It's called a lockstrip. Try using that name and all kinda stuff will pop up. They come either plain black or with a chrome strip on the outside. They are readily available.
you are right. I have found the lock strip but am having no luck with the gasket for the back glass. They tell me 63 65 & 66 are available but that the 64 is different the panel below has rusted on mine in the corners & I would like to replace the seal after I fix the rust
