I need to re-install my back glass on my 64 Dart. I didn't take it out so Im not sure how the trim and glass go back in. Does the trim go in first then the glass/boot or visa versa?? I know the trim is held in with SS screws.
you should just be able to install that after you 1st) set the gasket 2nd) set the glass and 3rd) install the zipper lockstrip. BTW, the exterior chrome trim stuff is REAL fun to start the speed nuts if you have the round holes behind the plastic pieces inside, not so bad if they have slotted ones
