JefftheComputerMan
$5500 OBO Valiant Signet 200 Daily Driver, runs and drives great!
FULLY Running and driving MAGNUM SWAP!
1999 Dodge 5.2L Fuel Injected Engine with 44k original miles. Cranks and runs like a brand new car, added mini starter to clear headers if needed.
Have upgraded to 4 wheel disc brakes, with these wide tires IT STOPS on a dime.
Front end is 1973 Dart Disk brakes. All 5x4.5" Ford, Mopar standard pattern.
Disc Brakes on 1974 Dart 3.91 ShureGrip 8.25"rear end.
727 Torqueflite 3 speed with shift kit. B&M Shifter, Air shocks on back to raise or lower in a second.
Replaced ALL bushings, upper and lower ball joint, lower control arm bushings, axle bearings, tie rod ends, ect... Rides very smooth, no squeaks, no clanks...
2.5" Exhaust sounds nice
Tires are BF Goodrich 225/60 R15 on Western Wheel slots all around with 2 spares on 225/70 R14 on pretty clean Cragar rims. All tires have less than 2000 miles on them, brand new condition.
3 Core aluminum radiator, electric fans, runs cool even in Texas has AC pump on engine (not connected but easily reconnected)
Electric aftermarket seats. Really good interior.
Big speaker box in trunk with amp and 2 x 10" subs
Primered body with minimal metal problems, no major rust or structural problems.
Classic 64 Plymouth Hotrod 2 door
