74360duster
JEREMY
After 6 Years Of Sitting On Stands In The Back Of The Shop.we Finally Started The Engine In My Fathers 64 Sport Fury.had To Blow Out The Fuel Lines And Install My Carb.but It Fired Right Up On Carb Cleaner And Once It Primed The System The Car Ran Excellent.lifter Chatter For Couple Of Seconds.we Finally Got Caught Up On Working On My Cars And Decided It Was Time To Get His Car Fixed.(mom Also Said To Drop The Insurance Or Get It Running)they Have Had The Car For 30 Years.the Reason For Being Parked So Long Was The Trunion Joint In The Driveshaft Came Apart And Cracked The Tailshaft On The Transmission.finally Got A 65 Plymouth Trans Which Will Now Have A Slide In Yoke And Also Maintain The Factory Cable Shift Operation.looking Forward To Cruising With My Father In The Next Couple Of Weeks.it Was Great Hearing The Car Run Again.new Engine In The Projects.should Be Installed This Spring.then To The Body Shop.car Has Only Got Small Spot Of Rust Over Right Rear.and Only The Driver Seat Insert Needs Fixed.original Paint And Interior.
