64 valiant four door
newmexguy
Las Cruces New Mexico USA
64 valiant four door. southern new mexico body. Clean doors, trunk lid and hood. Good rockers and frame rails.
am not going to disable this car from rolling but will sell removable and other parts off it such as:
hood, hinges, springs and latch assembly
trunk, hinges, spring and latch
rear quarter sections
right rear floor pan
e brake cable guides
roof
a pillars
b pillars
c pillars
rear package tray and trunk divider(s)
dash shell
cowl and firewall
front hinge jambs
Do you have the L & R front "splash shields", the big ones on the front side? I think that is the correct term. They are behind the headlamps and fit between the outer fender and inner fender. They are missing on my 64 Valiant. I have extras from my 65 Dart, but the Valiant has a different fender with a wedge, so would have to cut to fit.
They are metal, with a rubber type seal flap attached along the edges. Photos of 1966 front, inner splash shield I borrowed from an old post. The 1964 Valiant is similar, but slightly different shape. I don't need the smaller aft ones.
