65 Barracuda Speedo Cable
CrossRam65
Active Member
L.A.
Hey guys... Is it a threaded collar that holds the speedo cable to the back of the speedo on a 65 Cuda? Not a lot of room to work there. Replacing entire panel and new speedo is electric. THANKS!
Should unscrew just reaching up in there and tracing the cable housing to the back of the gauge.
Are you going to remove the panel to do the work afterwards?
I'm having a new custom panel made to replace the stock one. I tried turning what looks like a grey collar on the back of the gauge but it doesn't budge. I just need to know if its common to need pliers to turn it. As I mentioned not a lot of room there. Seems like should be simple, but with old cars you never know.
Shouldn't be pliers necessary but... old car.
Have you thought of just easing out the whole panel so you're not having to feel around under the dash?
