Keezyus
Active Member
Hey guys,
I have a 65 dart 273 4 barrel with a Edelbrock 1901 on it. Did a reseal all around the engine and put a new fuel pump on it aswell. Have the pump in correctly because when I take the lines off, I get sucking and blowing on either end of the inlet and outlet fittings. Question is, why am I not getting any fuel to the carb from the pump? Won’t start because of no fuel. Getting spark so only thing is this. Put a new inline fuel filter between the two on the line and I have it in correctly with the inlet, away from the carb side. Please let me know if you have any ideas!
