65 dart exhaust manifolds
haole
USA
Installing a 360 in my 65 dart. What is the best fitting exhaust manifolds to use ? Late model Dakota truck ??? Any suggestions ??? Thanks.......
the stock stule 273 manifold would fit the best but choke the hell out of a 360. don't know how a dakota manifold would even fit in there, i suggest the spitfire headders. they fit and perform.
like to see more pics. that drive side manifold dumps right on the starter. gonna be a ***** getting a pipe to that thing. even then what size pipe you running to it? i'd go spitfire before i went that route. that guy is so proud that the manifolds fit they he included one crappy picture.
Haole,you don,t mention wether you have manual or auto?Same with your steering,manual or power?I just finished putting a 360/904 with manual steering and had used the Spitfires.They won,t work with power steering or manual trans.Hope this helps!There,s a sticky in the exhaust forums on headers in a early A.
Good info .................Thanks everyone !!!!!!!!!!!!!!!!!!!!!!
