65 Dart Manual steering radius?
mycuda
Chicago/ Metro
Just got car on all 4's. Magnum 4spd swap. 1st man/steering project(maybe last)
Drove around parking lot realized not much radius.
Checked underneath, no interference on v8 link,front disc setup etc.
Don't look like more than 45-50 degrees either way?
Normal?
Thanks, Dave
Were the tires squealing at all? Is it power steering? The only thing that comes to mind is that the inside wheels of the a turn aren't turning sharper than the outside wheels.
Here what your saying, but tie rod end threads un touched since /6 was in and driving straight. So don't believe alignment an issue.
How many turns lock to lock? Stock was 5 turns lock to lock I believe.
Sounds like it's doing what it's supposed to do.
Did you do a disc brake swap ?
If so did you use the Kelsey Hayse 4 piston or the ‘73 up single piston calipers ? Or after market system ?
After market but nothing hitting on turning
full either direction.
That was my first thought.
but it is what it is I guess...
