Need to locate the vin.The tag on the door is gone.Would the number on the radiator support be the same or is their somewhere else.Have police coming out to assign me a number but if i can find the factory number would be better?
Can you post a pic of the data plate screwd on in the engine compartment? I can tell you if I see it.Need to locate the vin.The tag on the door is gone.Would the number on the radiator support be the same or is their somewhere else.Have police coming out to assign me a number but if i can find the factory number would be better?
Forgot about build sheet will check for that
What about inside the driver door by the hinge?
Found title with vin on it.Radiator support had no.760706132 on it.Now i need to know where i can get a vin tag for the door made.Have title with vin also checked buildsheet all torn up nothing left.
That number on the radiator support is the shipping order number and the last 5 digits will (or should) match the digits under the word "NUMBER" on the fender tag. To my knowledge no one is reproducing any kind of tag or plate with a VIN number on it - something about against Federal law. Your missing VIN tag is made out of stainless steel and is is about an inch or so by 2 to 3 inches and was secured with some kind of special glue. All 5 of my early A Bodies have the tag and no rivits holding the tag to the jamb.
