65 Dart Voltage regulator for Gauges
65Vart
Waterdown, Ontario
Hello everyone,
I have the dash out of my 65 Dart, replaced the fuel gauge that got toasted by the gauge voltage regulator. Where is the regulator. I thought it was on the back of the cluster. If this does not work I will be installing an Autometer I got from a member. I thought since the dash is out I would repair it.
The voltage regulator for the gauges is incorporated with the gas gauge. If you replaced your gas gauge with a new one, you've replaced the regulator.
Well, I replaced the fuel gauge put the dash back together, and still nothing, checked the ground everything. I guess it could be the sending unit. I guess I will find out when I hook up the AutoMeter. Thanks for your help DartMan. I appriciate it(Finally got around to that gauge(s) you sent me).
